Relayed H4 Headlamps
  • CR500Dom
    • Oct 2004
    • 237
    Right, I have been pulling my hair out over this
    I have done a new Standalone Lighting Harness for the headlights and another one for the Lamp pod.
    The lamp pod workd fine and has done from day one.
    The Relayed headlamp loom has not though ?
    This is exactly the same design of loom as I have used on lots of VW`s.
    1 5 pin Relay for Dipped beam
    1 5 pin Relay for Main Beam.
    2 Relay sockets,
    2 Fuses in 30 feed
    3 wires with Male spade connectors plug into NS (LH) H4 bulb connector, these are the 2 switch feeds, 1 for each relay, and relay earth(common to both).
    New H4 Bulb connectors
    2 87 pins on each relay, feed for RH & LH, Hi And Lo beam
    Remaining socket on H4 Connector, earth, linked across RH & LH Lights, then to ground.
    This is the way I have always done it, because if there is a problem, you can change back to standard loom in 2 minutes, also you can remove from the car easily when you come to sell it
    Problem is:
    Low beam comes in ok, hi beam comes on but does not go off.
    Same with flash.
    Turning lights off completely and back on resets everything until you touch high beam again
    Flash on its own without the light switch on works as it should....
    What am I doing wrong ?
    Is there something specific I have to do on this car ?
    I am pulling my hair out with it now
    I have checked continuity with A DMM, and all the wires are connected where they should be, I have tried different relays and swappped them into the Pod Loom and they all work as they should ?
    I am totally lost for an answer now
    Any sparkies out there know what I am doing wrong, or anyone want to send me a number and talk me through troubleshooting it tomorrow ?
    As Always, any help gratefully received
    Dom
  • Mikes2
    • 1704
    Does the car have autocheck ?
    This can cause problems.
    Mike
    http://www.s2-audi.co.uk
    • s2carlo
      • 252
      A wiring diagram would help!
      It would make it easier for you (and us) to (help) diagnose the problem!
      Regards
      Carlo
      2 Relay sockets,
      2 Fuses in 30 feed
      Problem is:
      Same with flash.
      Dom
      No power, no glory!
      S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
        2 Relay sockets,
        2 Fuses in 30 feed
        Problem is:
        Same with flash.
        Dom
        Post a diagram of what circuit you built with those relays - its impossible to work out from the text what you have done... but something must be wrong if the main beam relays are latched on.
        Paul
          Bad ground somewhere?
          I'd guess the relay earth you're getting from the old H4 connector is a bad ground or theres a bit of current leaking between the 2 circuits. If it is a fault with the car wiring you should be able to see the headlight glowing if you go back to a stock bulb setup. It doesn't take much current to hold the relay in.
          I'm going to make myself one of these looms soon, have just ordered some Philips Vision Plus H4s and some Xenon Ultrawhites, going to do a comparo..
          Where do you get your relays and H4 connectors from? Is there a source online?
          • CR500Dom
            • Oct 2004
            • 237
            Ok ,
            I have changed the ground wire from H4 Connector to Battery grond, still no difference.
            The standard vehicle wiring is still intact and works as directed, I am unsure whether there is a relay in the standard circuit that is being interfered with by my new circuit and where it is fitted in the loom.
            I have also run it attached to 2 H4 golf headlights while wired in to the audi loom, still does the same thing
            Wiring Diagram shamelessley Nicked and modified from www.20v.org
            Hope this helps explain ?
            Dom
            • CR500Dom
              • Oct 2004
              • 237
              www.vehiclewiringproducts.co.uk has everything you will need
                Circuit looks absolutely fine if that's what you have built...
                I remember fitting a similar relay loom on my old Type85 GT Coupe and it had a UK specific 'dim-dip' relay annoyance which had to be disconnected. I'm sure this is NOT fitted to UK S2's however.
                Checked all grounds are OK and you haven't got a loop/short somewhere that is tricking a relay ON ?
                Also wonder is it related to Autocheck - try diss'ing it and testing again...
                Paul
                • CR500Dom
                  • Oct 2004
                  • 237
                  Paul
                  Ah yes but would the dim dip relay be fitted to an `88 10v90Q
                  All Grounds check out OK, loom was built with new wire, new Crimp terminals, new relays and Heatshrink insulation, with Dielectric grease on all connectors.
                  All run through Braided sleeving for protection with heatshrink sealed ends.
                  No "Scotchlocks" in this loom
                  I`ll try and kill the auto check, but its not actually showing a fault...which may be the problem in itself ?
                  Dom
                    Maybe - my Type85 was 1987, and it was some sill UK legislation that brought the 'dim-dip' system. Seemingly it has been deleted by way of some newer fangled rulings from the empty suits in Brussels.
                    Paul
                      I had dim dip on my 89 100TQ FWIW so could be that.
                      • CR500Dom
                        • Oct 2004
                        • 237
                        Lookslike Mine has got Dim Dip, and according to this site: http://homepage.ntlworld.com/jim_has...ch/cables.html
                        It Caused Phil a problem too
                        Now still reading the site but as of yet cant work out how to disable this function ?
                        I am not bothered by it, I would much rather have decent dip and main beam lights than Dip Dip on Sidelight
                        If its dark enough for lights I`ll run with Dipped
                        I`ll have a look for the pink relay mentioned and remove it to see if that does it ?
                        Any other suggestions ?
                        Dom
                        • 4WheelDrifter
                          • Oct 2004
                          • 5773
                          • Country: Devon
                          I quite like the dim dip. I can sneak in easier late at night.
                          SS
                            Ta
