Originally posted by Doug_RS2
Instrument Cluster Bulbs - again!
I am getting some of these red bulbs to see if they glow more red:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...71930&tc=photo
I'll report back when I get them fitted. (still waiting for them to arrive)S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
That wiring mod on the back is wierd, does it look like someone has done it?? Maybe thats why the dash lights go out. Thats cool tho, no distractions when on main beam nailing it down the back roads!!! I want to do that to mine.sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
I didn't get the red ones though,,,I got the white. They were a bit brighter than OEM but that didn't matter as I just turned down the dimmer a touch.Originally posted by Doug_RS2I am getting some of these red bulbs to see if they glow more red:
Expensive I know,,,,but they last forever,,,,,were still working ok when I saw the car a month or so ago.Last edited by Jas11n; 3 February 2005, 12:17.2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)Comment
How many do you need to do the whole dash? I want to order some.Originally posted by FourringsI got some of these when I replaced the dash bulbs in the old 2.3e.
Expensive I know,,,,but they last forever,,,,,were still working ok when I saw the car a month or so ago.Comment
What would happen if you put blue ones in?Originally posted by newshHow many do you need to do the whole dash? I want to order some.Comment
Just fished out the invoice,,,,I bought 15,,,seem to remember I had one spare.Originally posted by newshWhat would happen if you put blue ones in?
Not sure if the white ones will be ok in the S2 clocks,,,I fitted these white LED's in the previous car,,,,,exactly the same as the S2 clocks (VDO not UN4, with the on-board computer,,,,,but obviously not gray faced)
The dash still lit up red/orange because they shone through the red/orange opaik cutouts in the dial faces,,,,,don't know if the grey S2 clocks have clear cutouts, hence the reason for the rubber cap things on Dougs,,,,,,,If you know what I mean,,
Hmm, 15, lots of bulbs!
Just read a write up by a kiddie on that site who did the cluster in his Clio, he took it all apart and sanded off the back of the dials to get rid of the orange colour.. If I had a spare set of guages I'd give it a try.
I have a problem with my LCD computer display anyway.Comment
Just done a quick piccy of what they'd look like with blue bulbs behind (Blue led torch through a spare dial face) Gauge face is from a spare set of clocks (UN4) I got through ebay so I could do a run through of taking them apart,,,,without messin the old 2.3e's upOriginally posted by newshHmm, 15, lots of bulbs!
The blue still shines through the orange opaik (am I spelling that right?) cut outs
Sorry about the quality,,,camera phone,,,,got no batteries for the new digi camera
Doug,,,as Tom says thats not normal,,,some sort of bodge up there, maybe got something to do with your main beam problem. Not sure but I think one of those two that are "wired" together is the main beam bulb.Originally posted by Doug_RS2I also have a strange wiring mod in the back of the cluster - a "WTF" moment - one of the wires has fallen off as well
Can anyone tell what bulbs the two bulbs light up?
I have a strange thing on my lights - when I put main beam on - all the cluster lights go off apart from teh blue main beam light!Last edited by Jas11n; 16 January 2005, 00:36.2001 Avus Silver B5 RS4.
not on my cluster...no additonal spag wires to be seen, even on my spare set of dials.
clear LEDs will do as the dial faces create the red effect on mine.
inderesting to note that I have seen 3 different shades of dial colours on the S2. Not the faces but the backlight...seems that some of the bulbs have a little rubber red sock too on some models: Like tiny red rubber condom.1995 S2 Avant with some upgrades
Designun Limited....
Aerospace, Space and Motorsport Design Consultancy and hardware supply.Comment
There is defintely something wrong! Those wires are a bad idea as you can easily connect one bulb the wronfg way round to short out the +12v to Ground when you put the high beam light on!
I think this is what has happened and it took out some more stuff:Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Fecking previous owners fiddling
so fixed it:Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
