Hi all,i ran into problems with my ecu i purchesed months ago.i just gone and fitted the ecu and harnes to my project car,and tryed to start the thing and it throw a fault out saying (engine start blocked by immobilizer) i dont have any transponder keys or a immoblizer fitted.if any body knows how to bypass this system without rechipping the ecu it would be good thanks. ecu 895907551b
my bad, i seen you posted the part number it in the first post. anyhow, im sure there is a way to disable the immobilizer in the code but i dont have a factory bin file for that ECU. another idea is to switch to a different chip set that doesnt have a factory immobilizer like the 895907551AA chip set. those shouldnt have the immo from the factory.
"The really good drivers got the bugs on the side windows." Walter Röhrl
Here is an example of the immo on and off on a 4A0 907 551C ECU from AAN URS6.
The top file is bone stock and the bottom is with the immo disabled. you have to correct the checksum as well when you do this modification.
I cant tell ya if the immo code is at the same hex offset in your ECU as it is in this example but it should be in the same area. its always right at the end of the main code but before the maps themselves.
Hope this helps ya out man.
If I have read your info right you have a late ABY ECU which has an integrated immobiliser. If you don't have the ignition barrel and keys then you either need to get the ECU coded to remove the immobiliser or use an emulator which RJScotty linked to. I believe these are your only two options with that ECU
I've tried one of the immo eliminators and it only worked for about 4 starts then it stopped working,so theres a a6 immo with transponder keys on ebay looks like the early ones,i just thought this mite work?
