S2 avant electric rear windows wont work.
  • Monkeymagic
    • Mar 2012
    • 3419
    Guys the avant i recently bought has a rear window fault. Neither will go down..when i press the switch the engine revs dip very slighly as though they are drawing power but they dont move.
    I suspect they are stuck through standing. However itls there anything obvious to check like a relay etc. Steven..
    • 12431
    I dont think so, would be worth whipping door card off and trying to lubricate the mechanism first
    • Monkeymagic
      • Mar 2012
      • 3419
      It was my first thought. Cheers...
        Definitely sounds like the motors are stuck, one of mine was like this on the indigo avant. Sometimes a tap on the motor will make them run. If you need a window mech or two I have 2 complete spare sets here
        • Monkeymagic
          • Mar 2012
          • 3419
          Does anyone know if the rears use a seperate thermal fuse for the rears? Ive noticed the rear switches arent illuminated.
          • Christophski
            • 3632
            Have you tried seeing if its the switches at fault? Mine wouldnt work so I tried a working front one and they worked so I got new switches and put them in teh doors. Now I have fully working electrics again.
            • Monkeymagic
              • Mar 2012
              • 3419
              The only issue is neither rear works. I take it the fronts arent interchangeable.?
              • Monkeymagic
                • Mar 2012
                • 3419
                Switches that is.
                • bertman
                  • Apr 2007
                  • 1173
                  • Current: United Kingdom
                  Switches are interchangeable,try pulling the switch apart and use some very fine sand paper to clean the contact points.Both my rears were dead,I found upon looking at them corrosion preventing the contacts closing properly
                  Rob
                  Ragussa green avant RS2+ spec
                  Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
                  Audi coupe gt-slow as hell but loads of character-sold
                  • Monkeymagic
                    • Mar 2012
                    • 3419
                    Cool. Only thing is it wont work on rear door switches either... ?
                    • bluequattro
                      • 2960
                      Pull the rubbers back on the pillars and see if any wires broken
                      Don't they work from drivers door?
                      Put washing up liquid between window and rubber, may be stuck there and need freeing off, happens on my type 85 every so often
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        I have looked in the boots all looked good, the rear windows dont work from front or rear. Ill get cracking on it and report back
