Having trouble connecting vag com or my hand held fault code reader.There seems to be a power supply problem to the white lead as when it is wiggled about the connection is made albeit for a second or two and then it just dies.
Is it possible that there could be a broken wire somewhere or a power supply problem.
There should be no problem with vag com as its a genuine ross tech item with lead.
could it be worth cleaning the the small earthing rings in the fuse box.
seeing as it doesnt power up my hand held scanner and the genuine vagcom cannot make a connection tells me that the problem is with the connectors??
Any help will be greatly appreciated
