Half of the lights in my instrasument cluster is off
  • Jonas_R
    • 3781
    • Country: Denmark
    So half of the lights in my instrument cluster if off.
    I have checked them all and changed the defective ones, but still about half are dead.
    Are the light bulps on the same pcb line?
    So maybe I can just add some wires instead if one of the pcb lines are dead?
    Or could I move tacho, fuel gauge, temp gauge, rpm gauge over to my old instrumenter cluster? I currently have a RS2 instrument cluster.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Taavi
    • Jan 2006
    • 41
    Have a good look over the PCB. Probably there is just a small crack on the track that can easily be soldered.
    • M_GORDON
      • Oct 2008
      • 1295
      • Home: Isle of Man Current: Vatican City State
      One day a led make a shortcircuit and my dashboard goes only the middle.
      Check ALL lamps etc.
      photobucket SUCKS
      • mdz
        • Jun 2012
        • 775
        • Country: Latvia
        IIRC each side of cluster had it's own ground connection for illumination. As Taavi said, check PCB for cracks and cold joints.
        • johne
          • Apr 2007
          • 1406
          I had the same problem and it was a crack in one of the pcb lines as it ran across the bottom. Sorry I didn't take any pictures. I just soldered a wire to join the track but not at the actual break, further away where it was easier to find exposed track to solder to.
          John
          • Jonas_R
            • 3781
            • Country: Denmark
            So I checked the PCB and it looks fine. Also tried with a different instrument and same problem.
            So if the blue and yellow plug have their own ground, maybe this could be the culprit?
            But does both sides share 12v?
            • Jonas_R
              • 3781
              • Country: Denmark
              Any ideas?
              • valjo
                • 1110
                • Country: Latvia
                i had same problems. i find out that i have cold joint in dash conector ....
                Audi Coupe S2 1993
                Audi V8 4.2 1993
                Audi cabrio 1998
                • andy10v
                  • 5996
                  Have you tried adding temp ground or power to see if either fix it and then check back?
                  Sold ABY-stock
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    By dash connector do you mean the blue og yellow plug or the connector soldered to the PCB?
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      No because I'm not sure what pin is ground and what is +12V at the blue connector.
                      • valjo
                        • 1110
                        • Country: Latvia
                        yes
                        Audi Coupe S2 1993
                        Audi V8 4.2 1993
                        Audi cabrio 1998
                        • Jonas_R
                          • 3781
                          • Country: Denmark
                          Yes what?
                          • valjo
                            • 1110
                            • Country: Latvia
                            I dont remember exactly color, but i advise you to check both or all connectors for poor joints
                            Audi Coupe S2 1993
                            Audi V8 4.2 1993
                            Audi cabrio 1998
                            • Jonas_R
                              • 3781
                              • Country: Denmark
                              Ok so not the plug but the connector on the dash. Problem is that I tried with another instrument cluster and it had the same fault. So I dont think that two instrument clusters will have the exact same error.
