A little help on pressure testing
  • Jonas_R
    • 3781
    • Country: Denmark
    Hi,
    Well will have to do some serious pressure testing.
    I was planning to block off the 3 small hoses going into the IM and then apply pressure at where the small hose connects to the diverter valve. However iam unsure what happens when i apply pressure since the fuel regulator will come under pressure aswell, will it hold the pressure or will the pressure leak out there?
    When testing the big hoses, i was planning on testing from the turbo outlet and the all the way up to the IM, does this seem right?
    How can i best test the WG? since my local dealer how change the WG membrane said the the shaft looked really worn or bad. IMO i dont value his word that high, but can i test if the shaft is oki somehow. I can get my fingers on a used WG for around 50£, but can one change the shaft?
    Also i have no idea how to test the PVC system since this also seems to be able to make overboost cutoff?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Jonas_R
    • 3781
    • Country: Denmark
    Hmm nobody that can help?
    /Jonas R.
      Jonas,
      the bit on testing to the IM is right.
      As for WG get hold of a mitivac tool and plug that onto the spare connection on the wastegate, pump its vacuum up and leave for a min or two and see if any pressure is lost.
      HTH
      • Jonas_R
        • 3781
        • Country: Denmark
        Greg:
        What about the part on testing the small hoses, thus that seem correct to you?
        /Jonas R.
