Well,
Just mounted a trial setup for the PCV system, and went for a spin. I then look under the hood while the car was in idle and saw grey/white smoke coming out of the lower crank outlet on the side of the block, the one with OD 30mm. Ofcourse the smoke was coming out of the hose that is connected to the lower crank outlet.
As far as i know, this means the my compression is ****ed and properly that 1 or more of the pistons/pistonsrings is broken, correct?
Here is a little video,
Download Here 2.9 mb
GOD i HATE MY CAR......
/Jonas R
/Jonas R
