looking at an s2 tomorrow for mate, audi didnt find anything wrong when it went in there, no codes etc logged, they think its the crank sensor.. but i dont as that should bring a code yes??, 94 i think, dizzyless with seperate coil dooberys(yes that is the technical term ).
Misfiring started under heavy load, now seems to be all thru the range sometimes, and intermittent. like running on 4.
but injector leads were pulled one at a time, and no noticable difference between the 5, so can't pinpoint to any one cylinder. didnt do that myself, will retry in the morning. Safe to drive the car like that or only test at idle?
Will test the resistance of the "plug leads".. and also check the fuel filter to see if recently changed/clean flow etc..
Anything else to check? I can't see anything using the search. I'm familiar with turbo basics but just not audi at all.. Definately sounds like ignition prob to me... Any way to test the coil packs with basic multimeter etc?? can you check their resistance etc anyway? doesnt appear you can from searches etc.. but i'd have thought you'd be able to..
Cheers,
S
Cheers,
S
