'94 S2 misfire. (info needed before fri lunch)
  • kingos2
    • May 2005
    • 129
    • Home: England Current: Germany
    definatly sounds like the problm i was having identical symptoms read a few of my threads and you'll see,best to start cheap like djavants always telling me get a set of the rubber boot things that go in between the coil pack and the spark plug they perish inside from the heat,oh and change the spark plugs to a nise set of platinum tip one's ot should be running fine after that.
    • s@.
      • Aug 2005
      • 27
      Update
      Audi had the car, and found a boost leak between the turbo and inlet somewhere.
      I couldnt really see half of it when i looked it over as i didnt want to spend hours removing all the stupid covers.. but I did block the intake and the hoses did start to collapse, however obviously leaking on boost is different to leaking off boost...
      The car is now "better" but still missing a little bit and at higher rpm..
      I have suggested to him perhaps the ECU needs time to settle down after spending time with an airleak.. i believe they run motronic? not sure what version, but the motronic in my car will "learn" and adapt its map to suit the sensor readouts to a certain degree..
      I have also found out that he has been running it on 95 octane.. I've advised to run it dry and use only super/97 etc... but whats the specific with this car? is it a high octane only engine? or did audi somehow make it so its happy on 95 despite the high boost??
      I'm guessing with the 97 and a bit of time it will now be fine.. but thought i'd let you know what it was, and hear your opinion on fuels.. i'd never run my car standard on 95 let alone tuned, and i think this s2 is alledgedly tuned abit, although i have no idea how etc.. it looks all pretty standard.. can you just replace the chips in them without uprating it any other way, or is there anything else people usually do for a quick boost?(no pun intended) it seems to be working off a boost control valve and external wastegate which i presume is normal setup.
      • BRY
        • 3755
        mileage?
        • S2 Ant
          • 3682
          sounds like coilpacks unless i missed something up above.
          at idle its not really gonna show, under load and more importantly boost, its harder to maintain the spark, so they will have to work harder, which is why it will then start playing up.
          Ant
          2011 Kawasaki Z1000
          • s@.
            • Aug 2005
            • 27
            #20
            I don't know the miles actually. lol...
            the misfire is now not noticable to most.. and only when driven VERY hard.. hence my thought about the fuel etc... it only seems higher rpm too now, not just on boost, above the 4-5k i'd expect an ignition problem to show...
            so what petrols do you all use? could 95 cause this if it's det'ing or does your ecu show a fault on knock? i know mine dont just cuts back a bit.
            • UUUdirs2newcastle
              • Apr 2008
              • 655
              Did you get to the end of the issue? What was it?
                Definitely run super unleaded on these. As for driving hard and getting this I had issues with the stock coils and it was like night and day once I switched to modern coil packs and one of Error404 's wiring harnesses that are plug n play.
                I have spare stock coils, but had recurring issues with them and the coil pack boots.
                • UUUdirs2newcastle
                  • Apr 2008
                  • 655
                  Hya Greg, I’m guessing that if I buy 1 x brand new BERU coil from eBay or online etc, I can fit just one of them, and wire it in where the ‘suspected faulty one is’ to use with my 4 old original Audi OEM BERU ones? I have a feeling that Cylinder #2 is the culprit, as the #2 spark plug is more ‘sooty’ than the other 4 !
                  What do you think buddy ?
                  This gallery has 3 photos.
                    • Dec 2017
                    • 5983
                    I have a good original coil pack set you can have for that price plus postage.
                    Or. I have 5 good OE tsfi coils for £100 and buy the conversion harness from Error404.
                      For the cost of a single original coil I’d spend the extra 80-100 and convert to modern coils as this eliminates the need for the two power output stages on the bulk head, you get stronger spark, replacement coils are cheap and you don’t have to worry about it anymore.
                      • Henkjan
                        • 1705
                        I have the said harness waiting for some coils... can I take them of your hands?
                          • Dec 2017
                          • 5983
                          With postage costs I think you can buy cheaper at home?
                          • UUUdirs2newcastle
                            • Apr 2008
                            • 655
                            Would a leak from one of the little 3.5mm vacuum hoses that are all over the engine cause this if there was one perished? They all seem a little iffy. Probably 26 years old !
                            • UUUdirs2newcastle
                              • Apr 2008
                              • 655
                              I have just changed one of my coils for a brand new BERU one, I put it on number 2 spark, as that one looked the most sooted up, but the car is the same. :-( It still feels like it’s missing when I go past 4,000 rpm more that 1/2 throttle.
                              • UUUdirs2newcastle
                                • Apr 2008
                                • 655
                                If I drive the RS2 all the way up to 5500rpm with just half throttle, through the gears, it feels ok. But as soon as you give it some welly, it’s just flat and feels like it’s misfiring.
