Right then, I'm having a small problem guys guide me through if you can.
I bought my 7A only 5wks ago of ebay. Seem'd in good nick when I got it and it ran well. AFter the first few days it started to flash the little symbol meaning low coolant/coolant temp too high!!!!
Then it popped the Top Rad hose.
SO!!!!
Changed the hose and the themostat which was rusted into the housing!!!!!!!!
I had a slight flat spot between 2-3000 rpm which seemed to move to anywhere in that range (not there if you gave it a bit though), so changed the diss cap and rotor arm (both knackered)
HEY PRESTO!!!
Everything Ran fantastic for a while, so I put some greased lightning through the fuel system to give it a clean, and way hey got more power back, the system must have been full of C***.
Now I lent the car to the wife as she got a flat in my PT Cruiser (Don't laugh they are very comfy for euro crossing journeys) two days ago, just before that I noticed that the flat spot was coming back and felt like the car was reigning itself back. Kept an eye on the gauges and the oil P is fine not a flicker same for voltage.
After doing a quick check I went to fill up before the pumps got to mad. Sat there for 10 mins and voila the coolant light came back on. Popped the bonnet and looked round no leaks of any sort anywhere.
Got home, let it cool, lost half a litre of coolant somewhere.
Topped up.
Wife took car yesterday.
Lost half a litre somewhere.
ANY guesses???????
Head gasket????????(please no!!!)
Water pump Bo******?????
Pipes are all fine unless they have a pinhole but that would show up wouldn't it???
Any way of telling if it is the Hgasket with the spark plugs?
Finally the Question is SHould it Stay or Should it go.
I obviously can't sell it to someone in this state without taking a major kick in the cost nuts.
Please rescue me. I only want to get it running smooth (without spending lots of money) get it through its MOT and then flog it to upgrade to an S2 with the cash saved in the mean time.
HELP!!
Azman
SO!!!!
HEY PRESTO!!!
Topped up.
ANY guesses???????
HELP!!
Azman
