Gregs has done this, here is a pics:
tuning options for RS2 spec 3B motor?
So can all the same 3B hoses be used or do I need to acquire RS2 hoses?Ben
Calgary, Alberta
Canada
1991 CQ e//S2 w/ RS2 spec 3B 20vt
Panther Black Metallic
www.moda-architecture.caComment
The 3B hoses work, the IC output hose just needs shortening. You should do the Mark H mod too, short hose to double up the IC O ring which tends to leak at high boostOriginally posted by archiboy24So can all the same 3B hoses be used or do I need to acquire RS2 hoses?Comment
Yeah, that's good advice. I haven't done that one yet.Originally posted by newshYou should do the Mark H mod too, short hose to double up the IC O ring which tends to leak at high boost
Ben
Calgary, Alberta
Canada
