Help Help Help
    Charlie, if you do need a couple of senders I have some in the garage from when I rebuilt my engine
    • charlie
      • 447
      Greg You have PM.
      RS2 MTM
        good luck getting the car sorted, let me know if you do need them
        • charlie
          • 447
          Update
          Plugged in Vag-com
          FIRST CODE: 00513 ENGINE SPEED ON SIGNAL G28
          SECOND CODE: 00514 CRANKSHAFT SENSOR NO SIGNAL G54
          Removed crankshaft sensor which had some damage to cable with insulation
          stripped. P/N 034 905 381 A
          No more fault codes appeared.
          RS2 MTM
          • dan_b
            • Sep 2003
            • 3670
            #20
            Does the car turn over now those fault codes have gone?
              #21
              Originally posted by charlie
              Plugged in Vag-com
              I'm sure that G54 should be G4... If you are getting both these codes, then maybe G28 and G4 are indeed swapped. G4picks up the crank reference pins at 62 degrees BTDC #1 - telling the ECU where the crankshaft is. G28 counts flywheel teeth - telling the ECU how fast the crank is rotating.
              More info here - http://s2central.net/motronic_02.html
              Paul
              • charlie
                • 447
                #22
                Car has always turned over but never fired.
                RS2 MTM
                  #23
                  Have you tried swapping connectors for G4 and G28 yet ?
                  Have the fault codes all cleared now ?
                  Paul
                  • charlie
                    • 447
                    #24
                    Paul
                    First code was the first interogation. I presumed this was a common fault
                    code as engine was not turning. Cleared this code. Do know how long this code
                    has been their cause last time i checked codes was about 8 months ago.
                    Second code was second interogation. only this code showed. removed
                    crankshaft sensor cleaned it, checked terminals, checked connectivity and
                    continuity/resistance.
                    This is when i noticed split in insulation and sheilding.
                    cleared ECU code, reassembled, turned over engine
                    and checked codes again .
                    Same code appeared and no other codes appeared.
                    Ordered a new sensor. will install tomorrow and see what happens.
                    RS2 MTM
                    • charlie
                      • 447
                      #25
                      Installed two new crankshaft sensors G4 & G28. No luck.
                      FUEL LINE PRESSURISING BUT NO INJECTOR PULSATING/FIRING
                      ALSO NO SPARK.
                      RS2 MTM
                      • sal_s2
                        • 1287
                        Have you connected the two earth wires that attach to the inlet manifold?
                        • charlie
                          • 447
                          #27
                          Yes but will double check tommorrow.
                          What would stop spark plugs and injectors from not firing
                          RS2 MTM
                            #28
                            Assuming you have G4 & G28 wired to the correct plugs. You should also suspect -
                            G40 - the cam position sensor - this was discussed as well as G4 & G28...
                            A dead G40 means the engine cannot start...
                            Another suggestion - have you checked ALL the Motronic fuses ? You might have blown one when you had the wiring damage !
                            Paul
                            • charlie
                              • 447
                              #29
                              Items Checked
                              1) Montronic Fuses Both Ok
                              2) All Earth Straps Cleaned,replaced & Tested With Voltmeter
                              3) All Conectors At Bulkhead, Cleaned And Checked Pins
                              4) Fuel Injector Wire Have 0.3 Volts Pd But No Negative
                              Pulse To Trigger Injectors
                              5) Coil Pack Has 12volts Pd Supply On Yellow Wires
                              And Earth Is Good On Casing Cover
                              6) The 3 Wires That Connect To Camshaft Sensor Have
                              5 Volts, 4.88 Vlots & 0.13 Volts Pd Between Them
                              Please Can Anyone Measure And Tell The Resitance Between
                              The 3 Wires To The Camshaft Sensor (hall Sender)
                              Mine Is Showing Infinate Resistance As In No Connection
                              Between All 3 Wires. Normally 2 Show Some High Resistace And
                              1 Infinate.
                              Pd = Potential Difference.
                              RS2 MTM
                              • charlie
                                • 447
                                #30
                                RS2 MTM
