Oversize Pistons
  • Billman
    • 4129
    #31
    thats the problem! Anyone used something like this before??I mean the Block - crank- rods kombination or something like that! Maybe shorter rods or i dont know!
    Go Holset or Go RS4
    • Billman
      • 4129
      #32
      well i have just got this reply from Sten Parner (Question was what pistons to use with the 158mm 23mm pin rods on diesel Block and Crank):
      Hi
      The best way to do a cheap engine is:
      Diesel block,Diesel chrankshaft,pistons from gas engin 5 cyl,SPM 155mm
      H-rods
      The rods handle muck power(4Cyl 1127 BHP and 10500 rpm AND 7,38 sec.on
      the
      strip)
      Best regards
      Sten Parner
      But i think that it would better to run the longer rods with the Bigger Pin diameter!
      Go Holset or Go RS4
      • AnLe
        • Dec 2003
        • 291
        that receipt gives 9.4 compratio as post to orginal around 8.9-9 makes hard to tune such high comprate, plus the squish area is lowered to very bad levels. I would not lower the piston deck clearance, this one would make it 0,45mm under deck level.
        • Billman
          • 4129
          #34
          I think maybe he has also pistons for Audi 5 cylinder to lower compression ratio! Dont know! Still like more the longer 158mm rods with the 23 mm pin diameter!
          Go Holset or Go RS4
          • AnLe
            • Dec 2003
            • 291
            23 pin is good idea, 158 is too long, piston would be thin as paper.
            • Jon441cc
              • Dec 2005
              • 2061
              How about a groupbuy on some custom cosworth pistons
              • mcandmar
                • Apr 2004
                • 5118
                I was thinking the same thing, Dom gave me some contact details but i havent got around to ringing Cosworth yet. I think its best to sort out the rod group buy first as i doubt people can afford both at the same time, i know i cant
                91CQ20v - Gone to a new home
                93UR-S4 - The Magic Carpet
                94S2Bus - The Emerald Express
                • Jon441cc
                  • Dec 2005
                  • 2061
                  I agree
                  • Billman
                    • 4129
                    #39
                    me neither now!
                    Go Holset or Go RS4
                    • olsonjus
                      • Dec 2003
                      • 293
                      Who sells CP pistons? I'd really like a set for my stroker 20v
                      • Billman
                        • 4129
                        #41
                        what do the others think about this?? (We talk about AEL-AAT Diesel block and Crank)
                        Go Holset or Go RS4
                        • lukach
                          • Jan 2006
                          • 124
                          #42
                          count me in..
                          • Jon441cc
                            • Dec 2005
                            • 2061
                            Originally posted by lukach
                            count me in..
                            There isn't a group buy yet :mischeif:
                            • olsonjus
                              • Dec 2003
                              • 293
                              JRC motorsports is a very good place to get JE pistons from. They sell them for $693 + shipping. Thats where I'm going for my set.
                              "A set of five pistons for your 20V is $693 with rings. It will take about 2
                              weeks to fill the order.
                              Sincerely,
                              Rodney Huss
                              704-864-1995"
                              Regards,
                              Justin
                              • Audi Parts Guru
                                • 1317
                                #45
                                Looking for options for oversize pistons, what brands have people used?
                                So far i found....
                                Mahle = seem to cost more than customs
                                JE = I know some of you are using them, any issues?
                                Eurospec = Havent heard anything good or bad about them?
                                ... I need more suggestions please, the cheaper the better
                                Mark.
                                What size piston are you looking for?
