Oversize Pistons
  • olsonjus
    • Dec 2003
    • 293
    I'm getting a set of stroker pistons as well, so those will be included in the GB. Coatings are extra, but can be had if specified. I will get prices on them today.
    The JE vendor this is being run through is a big audi/vw engine builder, and the JE's he sells have no issues with thin aluminum around the valve reliefs.
    Regards,
    Justin
    • Mark Halligan
      • 2001
      Originally posted by Billman
      @Mark
      Where is the problem point of Je's valve pockets! I have heard that some people had problems with them!
      Yes I did have a problem with burning out the thin metal around the pockets on two pistons due to detonation, don't know if its happened to anyone else.
      In the next set I just asked JE to mill that area away, like OEM pistons, as in the pic I posted above.
      They did no problem, no extra cost, and it makes the pistons a touch lighter too.
      Mark - Modded
      • Billman
        • 4129
        #63
        Regards,
        Justin
        Can we also make a group buy for the Summer time! Due to the Rods Group Buy i am short of car-project - and overall money!
        Go Holset or Go RS4
        • olsonjus
          • Dec 2003
          • 293
          I spoke with the pistons vendor today. We'll see when we get all of the people interested.
          We have a few options available:
          MTE(teflon) skirt coating: $88
          FSR Strutted Piston & Heavy Duty Wrist Pin: $200
          Regards,
          Justin
          • olsonjus
            • Dec 2003
            • 293
            "Justin,
            I like the FSR strutted / slipper skirt pistons. They are a nice piece and work well on boosted engines that see high rpm use. This allows a shorter wrist pin and gives a weight savings in most cases. Without the barrel skirt, some people feel that it will rock more in the bore, it is all opinion. I strongly suggest thermal and dry -film/teflon coating the pistons to give your engine a better advantage against wear and help free up the engine. I have the FSR's in my own personal engine (without coatings) and will be building a second motor in the future to replace it with coatings on bearings, journals, pistons and so on to see what difference it actually makes in power output (I have a company that will coat the parts for me free of charge for testing). The only other thing that some people choose to question is the lock design (spiral, wire or tru-arc). I have used all three. I do like the simplicity of the tru-arcs, but fell the spiral locks are the best insurance for preventing failure, but are a bitch to remove if the time comes (but I do have a nice tool for removing them).
            Sincerely,
            Rodney Huss
            704-864-1995"
            • Billman
              • 4129
              #66
              Pisobiker in his project had Moly coating on the Skirt and Ceramic on top! For what are these good?
              Go Holset or Go RS4
              • slow2
                • Apr 2004
                • 238
                Short version
                Moly coating on the Skirt= helps to lower friction between piston and cylinder bores
                Ceramic on top!= helps with thermal protection of piston crown
                Dez
                Never did overtime until i purchased........s2
                • olsonjus
                  • Dec 2003
                  • 293
                  Here is the link to JE's catalog. Download it and check it out.
                  Regards,
                  Justin
                  • olsonjus
                    • Dec 2003
                    • 293
                    http://www.jepistons.com/pdf/2006-sportcomp.pdf
                    • AnLe
                      • Dec 2003
                      • 291
                      have you seen orginal rs4 piston, it has very short pin, seems very nice idea to shorten the pin.
                      • martinjs
                        • 3205
                        At what power level is it advisable to go with a bigger diameter wrist pin?
                        • AnLe
                          • Dec 2003
                          • 291
                          if custom piston is needed - bigger pin is needed ? even if it is not nessesary at time of installation, it leaves room to update, becouse its never enough
                          • olsonjus
                            • Dec 2003
                            • 293
                            People are making 200hp per cylinder on 20mm pins. I'm not sure that you need to go up a size. Thats just my opinion tho. On my motor I'm going to a 21mm pin because pauter already makes 159mm rods made for a 21mm pin.
                            Regards,
                            Justin
                            • Billman
                              • 4129
                              #74
                              i am going for a 23mm Pin ! Hope its not going to be tooo bulky and heavy! Sure its going to hold some power!
                              Go Holset or Go RS4
                              • olsonjus
                                • Dec 2003
                                • 293
                                The weight of the pin will go up, but it should be fine. You'll be set to run methanol and 50psi
