RS2 Airbox question
    RS2 Airbox question
    Can you guys with RS2 airboxes answer me this, in the pics below you can see that on the ABY box the heat shield wraps round the lower attachment point andon the RS2 it doesn't, does this mean my heat shield has been modified or are all Rs2 boxes like this? I think this one may have been snipped to clear a larger turbo?
    Ta!
  • s2avant
    • 2426
    Mine was brand new and is exactly the same.
    Ben
      Ben
      Thanks Ben!
      • Corey
        Banned
        • Sep 2003
        • 2793
        One point, more out of curiosity, if the RS2 box is the one to have? To me it looks the same except the intake, if that is the case then why not just create a new intake. Obviously it would help if you have access to a lathe but would not be difficult to machine a new trumpet and cut the old one out and plastic weld the new one in.
        Just a thought, makes no difference to me as I can't use this on the S6 but just a thought.
        Corey
        01636 822288
          The top of the box is a different shape too
            Yeah, the box splits in a different place too so there's a bigger volume of air above the filter , I'm sure you could improve the ABY one though as you say, some plastic gutter pipe maybe?
            This mod has made a surprising difference to how the car runs, I want to dyno it again now.
            • Corey
              Banned
              • Sep 2003
              • 2793
              Yeah I can see that now.
              I was thinking more of a machined intake trumpet so that the air is as smooth as possible entering the airbox.
              Corey
              01636 822288
              • Audi Parts Guru
                • 1317
                Corey, it is different. Take a look at the top half of the casing for example, you'll see that the RS2 one is thicker.
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  I can see now (again!!!)that but I am trying to think of a cheap, effective mod for the ABY, not that I have an ABY one to hand but just sounding out the possibilities.
                  Corey
                  01636 822288
                  • Silverboy
                    • Feb 2005
                    • 159
                    • Home: Norway
                    does the rs2 one always hit the under bonnet clothing or have I not got mine in the correct way?
                    • s2avant95M
                      • 1217
                      • Home: England Current: United States
                      you also need the RS2 part for the headlight cover thing, dont know the part number off the top of my head but i could find out.
                      Tim
                      1995 S2 Avant, ruby red - ** SOLD TO ROSS **
                      Golf Rallye G60 ** SOLD **
                      Golf MK2 Oaky with R32 engine
                      Audi A6 Avant 1.9 TDi 130
                      Golf MK2 8v Race car
