Originally posted by rspeed
auto cad; engine mounts
Originally posted by AnLefriend made them, they look nice, they work nice, and they give more noice than hydros but they are far away from solid ones.
The rubber was hard to find, needed to find such diameter of rubber that there were same insidediameter of pipe to make it heat resistant, and those big washers, the idea was to save money and not to use polyurethane(?) but to make it last the beating, good support was needed, and to kill 2 birds at once, the pipe under and upper shielding the rubber makes the 5mm thick plate very rigid.
dont you get engine sound transfer in to the chassie?ABT C5 Lord Of The Rings
2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
kostic.nuComment
Originally posted by AnLeyes I did, not too much, my setup was not the silent one in the first place..
(well 3" exhaust, h&r+bilstein 4" downpipe, etc)
how did you fit the 4" downpipe??ABT C5 Lord Of The Rings
kostic.nuComment
sorry to late answer, forum doesnt any more remind you have a reply..
damn it, it was 3.5" and there is 3mm room to gearbox and 4mm room to the steering rod? what ever it is named that turns the wheels, I had also 2 inch pipe from wastegate, it blowed under car, no silencer. It was fun to istall it, drop it down, turn 3/4 counter clock wise, then drop few inches more than 1/2 round clockwise and drop it into place.
