S2 3b engine problem - when cold
  • leo
    • Dec 2003
    • 101
    • Country: Poland
    There is malfunction in my S2 3B - it has an REV cut out when cold - the symptops are like this - when engine is cold it starts good, but when adding throttle it CUTS OUT the ignition at 1500 RPM - and don't let engine to rev higher than this. When engine getting warmer and warmer - it cut out in every minute a little bit higher - at 1600, 1800, 2000, and so, and finally when engine reaches higher temperature - about 60-70 degree C , it stops cutting at about 2500-2800 rpm, then ocassionally cuts out at about 3000 rpm, not every time ! - and when engine is hot, it never cuts out, except 7000 rpm ofcourse.
    The problem is VERY anoying - it's winter now, I got to first warm up the engine, before I can take a trip.
    VAG reports no errors... What could it be ? I only use Shell Vpower Racing fuel.
    Any suggestions are welcome!
    OOOO
    www.AudiKlub.org - the oldest and biggest Audi Club in Poland :thumbs:
  • leo
    • Dec 2003
    • 101
    • Country: Poland
    Hello!
    It's me, again Back to this - same car, same old problems
    What i've done in meantime AAN conversion, with new program. Problem seems to be the same...
    Any suggestions?
    Thanks!
    OOOO
    • s2driveruk
      • 12696
      There is a sensor on the rear of the head, forget the number but i seem to remember these go out of tolerance and then you get issues with cold starting. It sits directly below the small bore pipe from the rocker cover and has a two pin plug that pushes on.
      1992 3b S2 Coupe
      • s2driveruk
        • 12696
        http://www.s2central.com/ds_G62.html this one!
        1992 3b S2 Coupe
          Did you change the loom to AAN or do the pin swap on the 3B loom?
          • leo
            • Dec 2003
            • 101
            • Country: Poland
            Hi, sorry i forgot about this topic.
            Answering: we did pin swap and some wiring is added to the 3B loom.
            About my problem from the first two posts - recently i've encountered none of this problem... I think it is possible that some sensor is faulty and dying more and more... Have to check and replace.
            Thank You for Your answers, will keep it in mind!
            ps. it came to me that it is 15 years passed since I've bought this car... I'm old
            OOOO
