There is malfunction in my S2 3B - it has an REV cut out when cold - the symptops are like this - when engine is cold it starts good, but when adding throttle it CUTS OUT the ignition at 1500 RPM - and don't let engine to rev higher than this. When engine getting warmer and warmer - it cut out in every minute a little bit higher - at 1600, 1800, 2000, and so, and finally when engine reaches higher temperature - about 60-70 degree C , it stops cutting at about 2500-2800 rpm, then ocassionally cuts out at about 3000 rpm, not every time ! - and when engine is hot, it never cuts out, except 7000 rpm ofcourse.
The problem is VERY anoying - it's winter now, I got to first warm up the engine, before I can take a trip.
VAG reports no errors... What could it be ? I only use Shell Vpower Racing fuel.
Any suggestions are welcome!
OOOO
Back to this - same car, same old problems
