How to clean the throttle body?
  • Jonas_R
    • 3780
    • Country: Denmark
    Anybody have a guide or something that can help me clean the throttle body on my 1992 S2 3b?
    Or can I just take it off and clean it with ipa? And then mount it again? I know some newer audis, where you have to get a workshop to setup the tb when you mount it again after cleaning.
    /JOnas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    /JOnas R.
    Are you sure you are talking about throttle body, not the Mass Air Flow sensor ? I mean you are talking about aluminium thingy with potentiometer ? Or you are talking about plastic thingy ?
    If throttle body (the place where throttle cable connects), then just take piece of soft cotton cloth, soak it with ipa and clean it . I mean alloy parts inside. Potentiometer is not serviceable, you cannot clean it. Do not soak whole part in ipa. Here is one:
    If it's MAF, then do a search MAF cleaning. MAF looks like that:
    Good luck
    Sau
    • Jonas_R
      • 3780
      • Country: Denmark
      Meant the throttle body, know i cant do anything about the potentiometer
      And thanks i will do that, is it straight forward to change the potentiometer?
      /JOnas R.
      • volcano rs
        • Jun 2005
        • 2265
        use carb cleaner spray works really well
          /JOnas R.
          Yes, but there is a little procedure for ensuring the throttle pot is correctly in place - you need to check the idle switch activates in the idle position and that you get correct resistance readings at WOT. Fairly straightforward if you have a multimeter and can work from the schematic and pinout info at s2central.net. I should really post a more formal description of how to do this someday...
          Paul
          • Jonas_R
            • 3780
            • Country: Denmark
            Paul, can you post the link?
            /Jonas R.
