GT42R Install Pics
  • olsonjus
    • Dec 2003
    • 293
    GT42R Install Pics
    Here's what I've got going: GT4202R in my 91 audi.
    Downpipe needs some work as it has a 3" v-band on it from the gt40r. That should be a easy fix. Precision 850hp intercooler is on the way to me. Intake manifold will be fabricated this month.
    Motor is coming apart and I'm saving for rods and pistons right now. Trying to get this thing dialed before I'm a broke *** college student again.
    Should be a fun car when its all finished up
    Regards,
    Justin
    Jees thats a big one you have Justin !
    Be careful not to suck up small rodents in the vicinity of your workshop when that thing fires up. Care to tell us what engine internals and fuel system you are planning for this animal ? What is your target performance wise ?
    Paul
    • Jeffer
      • 2057
      The mother of turbo's
      That thing is HUGE man. When does boost kick in on your stroker with this puppy?
      Good luck with it.
      RS2 Black - stock 315 HP
      RS2 RS blau - stock 315 HP
      Sport Quattro - 1005 HP
      High Octane website
      • dan_b
        • Sep 2003
        • 3670
        My goodness look at the size of it
        • Jeffer
          • 2057
          I think you need to cut out your hood to give it enough clearance
          That thing will burn the paint of it in no time
          High Octane website
          • olsonjus
            • Dec 2003
            • 293
            Not up and running yet. Just test fitting it before I pull the motor out.
            For the motor I'm going to run a Eurovan shortblock with off the shelf 159mm pauter rods. The pistons are custom units by CP. 83mm bore, 29.25mm compression height, and 21mm wrist pin. The cylinder head is being done by RLZ Engineering:
            0.5mm oversized supertech valves on intake and exhaust side. Supertech Titanium Retainers, and supertech heavy duty valve springs. Lightweight hydraulic lifters. 7A cams to start out...
            I'm going to get a turbo blanket for the hood and hope it holds up. The turbo clears the hood no problem. I just bought some really nice motor mounts from 034efi that will hold the motor in place:
            For the fuel system I'm not really set on anything yet. I'm staying on gas for this motor. I thought doing methanol would be cool, but I will be able to make plenty of power with C16.
            My rough plan at this point is:
            Dual bosch 044 pumps intank with custom hanger.
            Y block into -10 Feed line from tank
            -10 Fuel rail (already have this)
            SX Fuel Pressure Regulator (already have this)
            -6 return line to tank
            I'm having a custom intake manifold built right now that is very similar to the unit Hacke has on his current car.
            Gotta get back to work.
            Later,
            Justin
            • olsonjus
              • Dec 2003
              • 293
              Here are some rough cad drawings I did for the intake manifold. There will be more room around cylinders 1 and 5 as they wouldn't get sufficent airflow if the manifold was built like in the drawing.
              Here is Hacke's design that I'm loosely copying. My design ends up being more symetrical than his. I'll report back about how well it works. I have a 75mm holley mustang throttle body as well.
              Regards,
              Justin
              • Faheemo
                • Feb 2005
                • 544
                • Country: South Africa
                Keep your hands in your pockets at all times !!
                S2 Coupe fully built.
                10.9 1/4mile 0-100 in 3.5secs
                Precision 6262 turbo
                The Green Monster
                  Sheesh kebab..
                  • QuattroFever
                    • May 2006
                    • 1360
                    What Power are you expecting??? Your gonna pull some serious G's with that badboy!! :mischeif:
                    Be careful, too many upshifts and you could end up punch drunk!!!
                    Volcano ABY coupe
                    Ant
                    • prosty
                      • Jun 2005
                      • 1114
                      Looks good. how does your intercooler core look like?
                      2004 9-5 aero
                      2009 Subaru Legacy Diesel
                      1994 Toyota Supra Eurospec 6-spd LHD
                      3-4 Audis in parts
                      • Rusty
                        • 18953
                        Wow! That Turbo's a beast
                        Hope you get it all up together soon so we can see it in action
                        • QuattroFever
                          • May 2006
                          • 1360
                          any updates on this monster??
                          Volcano ABY coupe
                          Ant
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Is that a fuel filter in the engine bay?
                            Chef
                            • BRY
                              • 3755
                              My thoughts exactly
