Can we make a total definitive list to be added to the FAQ section (with part numbers)
I'll dig up part numbers later to attach to each item
(I'll add any replies on to my list so that the final list stays in the first post)
From memory i have the following parts:
Timing Belt - 054 109 119H
Crank Bolt - 034 105 229A
Water Pump - 054 121 004AX (Exchange)
- Bolts to fit - N 010 247 8 (x2)
- Bolts to fit - N 014 717 2 (x1)
- Seal - 035 121 043
Crankshaft Oil Seal - 034 115 147 A
Thermostat - 069 121 113
Thermostat Seal - N 901 368 02
- Bolts to fit Thermostat housing - N 010 218 6 (x2)
Crank Pulley - 034 105 263A
- Bolts to fit Pulley - N014 726 3 (x4)
Coolant - G12+
Optional:
PAS Belt - 034 260 849E T - 12.5x1030mm (V Belt)
A/C Belt - 034 260 849 - 12.5x915mm (V Belt)
Alterator belt - 034 903 137B - 14.24x888mm (Ribbed)
Note: ABY Engine code P/N's listed here ONLY!
Coolant - G12+
Optional:
