Mtm Ecu
  • *ZenithalRavage*
    • 216
    Originally posted by horvathg
    Ill try the K&N filter again.
    Hey Horvathg, you've got K&N? How do you prevent your filter from sucking in hot air? Did you make your own heat shields or something?
    *ZR* S2 R.I.P.
    Visit *ZR*'s Hideout!
    • horvathg
      • Dec 2003
      • 556
      Zen,
      my K&N is a replacement type filter element that suits the box, so its not the cone type. However, as I complained earlier, when I tried the KN in the box, the car started to hesitate for half a second befora starting to accelerate so actually it was worse with the KN. After some hints from Dan and Glen I cleaned the MAF so I should try it once again but am I a bit lazy.....In Hungary it is some 35 degrees Celsius at sommer so the cone is not the best for the car I think.
      Gabor
      Gabor
      96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
      • *ZenithalRavage*
        • 216
        Zen,
        Gabor
        ah yes, the cone.. hmm... yeah it has it's own hassles, guess I'll just stick to the box for now then...... (the fact that I can't get all clips fastened (3B) put me to the idea to put a cone in....)
        *ZR* S2 R.I.P.
        • horvathg
          • Dec 2003
          • 556
          Zen
          I could show you my fingernails after filterchange.....*****. But after the 23rd attempt it usually clicks in. Replace the stock every 4 months or buy KN element for 60 euro.
          Gabor
          Gabor
