3B conversion to ABY...
  • Fat Audi 80
    • 10547
    LMAO @ that spaghetti!
    Good luck Tom, that looks like a nightmare squared!
    The Perfectionist
      May I suggest learning the colours through a tuneful limmerick or aide memoire such as (in the style of Dr. Nick from the Simpsons):
      The green one's connected to the... speedo,
      the grey one's connected to the... rev clock,
      the pink one's connected to the... fuel gauge... etc.
      • martinjs
        • 3205
        Yeah Tom, can you get me a full step by step guide on fitting this please?
        • twoqu
          • Sep 2003
          • 3103
          Hi!
          I think it looks worse than it is!
          There seems to be a lot of connectors as the whole engine bay loom is teed into the motronic loom at those cylinderical connectors. Basically they connect a lot of the other engine bay accesories, things like washer pump, brake warning level, hydraulic fluid, MFS etc, inputs for the gauges, turbo after run etc.
          So if you were transplanting this into a car without any of those you could effectively weed them out. The loom for the motronic itself is really self contained. You would only need the wires going to/from the ECU and sensors plus the Bat, ign and earth.
          With any luck it might just be a like for like swap. Perhaps Audi used the same colour connectors and pin position. Patience is a virtue I've been told!
          You haven't mentioned it but I assuming that you need to use an ABY ecu as well?
          If you get stuck, I have what looks like a 3B loom. Quite happy to spend some time with the DMM and identify what goes where!
          • Ross
            • Aug 2005
            • 3399
            Are you sure that's not a set of glorified christmas tree lights??
            Good luck Tom, looks like one hell of a job - good to know you're giving yourself a refresher taking the 3B to bits... coz mine's next
              #21
              Its not THAT bad... I have a spare ABY loom here I can refer to, as well as all the ABY schematics so it's just a matter of taking time to double check all pinouts and colours on each connector. Then labelling everything before assembly.
              Paul
              • twoqu
                • Sep 2003
                • 3103
                #22
                Originally posted by DJones
                Aelred is doing one at the moment..
                Hi!
                Looks like another cross related post.
                • audiman
                  • 4827
                  OMG!!! I took the dashboard and heater box etc out of the car today!!!
                  What a job. I need some BTDT help of where i need to plug the harness in. I started pulling wires out of the back of the fusebox, but i have extra wires on the 3B loom that are not in the ABY loom, such as a connector that seems to go to the oil/volt/press gauges?? WTF?
                  Also in the 3B loom there is a big fat power lead that plugs into the back of the under bonnet fusebox. The ABY loom doesnt have this? Why not!
                  Anyone who has done this fancy coming down to my workshop over easter?? I would make it worthwhile
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                  • audiman
                    • 4827
                    HELP ME OUT PLEASE!!!! I nearly torched it today! And I am serious!
                    Audi UR Quattro
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #25
                      I can help you out dude. I've got a 20 litre jerry can I bring with a lighter.
                      SS
                      • twoqu
                        • Sep 2003
                        • 3103
                        #26
                        Tom,
                        It's a bit late I guess but one way forward would be to patiently buzz each wire going to and from the ecu plug. One identified you only need to hook those wire back up to the vehicle. You can then seperate those wires from the loom. The motronic loom itself is realively self contained its all the other vehicle wires that are causing the prob. Basically the motronic loom only needs power (ign/bat) and earth! The only other wires that need hooking up are the signal out wires.
                        It seems the biggest problem you have is trying to transplant the loom in its entirity. Try to look at it as just transplanting the motronic components!
                        • s2dude
                          • Nov 2005
                          • 1631
                          Originally posted by twoqu
                          Tom,
                          Mmm. Sounds great in theory but I think in practice it may not be so simple ??! What do you mean "buzz" each wire going form the ECU plug exactly?? Test for voltage? or continuity or ??
                          and how does this identify them except to say you would have a reading of some sort?
                          Audiman.....if you didnt live 300 miles away mate I would come over and give you a hand....
                          • audiman
                            • 4827
                            What sort of excuse is that? LOL
                            I travelled to Scotland to help clear out Dougs garage!
                            Audi UR Quattro
                            • SteveH
                              • 4460
                              Tom,
                              I'll help you transplant the loom and you can help me swap my gearbox out...deal or no deal
                              Word of warning...I've never done a 3B to ABY swap, but I'm willing to help experiment on your car
                              91 Modded 3B
                              14 A6 Avant Black Edition
                              • sal_s2
                                • 1288
                                There is a power lead on the 3b loom because the battery is in the engine bay whereas on the aby loom the red wire goes to the back seat area.
