Gentlemen, looking for your knowledge or opinion here. What I find is that there is a whole bunch of engine modifications to be done, some which will make engine more reliable, and some who might increase engine HP. What I'm looking for is what modifications to do or not to do if the target is to get the turbo to spool up at a lower rpm. I hate the thought of giving up too much low or middle rpm torque.
To a certain extent if the engine is optimal for low engine spool up, it should be possible to use a larger turbo, with an even larger potential for high HP. My list of things to do on a 2,2 turbo engine is:
For better spool up:
Change exhaust cam (7A or ADU)
Tubular exhaust manifold
Free flowing intake (get rid of airbox, cold air intake)
Free flowing exhaust
3 angle valve job
Better tuning
What might work:
Port engine head, although I fear that low rpm torque might be hurt
Other intake cam
Retime echaust or intake cam
Then there is the best solution: Dielsel block and crank.
I guess there is also a "not to do" list here:
Wild cams
Short runner intake
Lower compression
Restrictive intake or exhaust
This is my list, all done in a hurry. I would like to hear if anybody has personal experiences, especially on items such as porting, valve jobs, intake, exhaust manifold, mapping and cams. What to do or what NOT to do.
Johan
3 angle valve job
Better tuning
What might work:
Other intake cam
Wild cams
Short runner intake
Lower compression
Johan
he have some wild idees i think!!
