Does anybody here run the GT28RS turbo?
  • S4turbo
    • Nov 2005
    • 81
    • Country: Norway
    Do you have any dyno charts, and what can you say about rpm where you get max boost, general experiences and so on.
    Johan
  • S4-Sleden
    • Dec 2005
    • 220
    • Country: Norway
    The GT28RS will be a bit too small for the 2,2 20v engine i guess. A better alternative is the GT 2871 which is used by alot of people on here. Max boost from around 2500 rpms.......
    2003 VW Passat Highline 130 TDI wagon with ALL options.
      There is a member with that turbo, it surges alot though better off with the 2871 .63 AR
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        The GT28RS is better suited to the 1.8T.
        SS
        • kalsket
          • Sep 2004
          • 78
          One GT28RS has just been installed to a urS4 with tubular mani. So far it has been test run with 0,8bar boost (RS2 stufe1+ chips), no problem. I'll let you know within couple of weeks how it works with bigger boost.
          4F 2006 avant 3.0tdi quattro
          4B 2002 S6 avant quattro
          typ85 sedan quattro with "minor" changes
          • S4turbo
            • Nov 2005
            • 81
            • Country: Norway
            Very interresting, please keep us informed!
            The reason for asking about this turbo is the claimed spool up at 1k rpm lower than RS2 with RS2 power potential, should make a very driveable car for normal day use.
            Jamo, can you get that member to coment on the performance?
            Regards, Johan
            • S4turbo
              • Nov 2005
              • 81
              • Country: Norway
              Any news with more boost Kalsket?
              J
              • kalsket
                • Sep 2004
                • 78
                Nothing yet.
                • maRS2
                  • Oct 2003
                  • 366
                  • Home: France Current: Thailand
                  Some news about this S4 with Gt28RS?
                  RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
                  • Jon441cc
                    • Dec 2005
                    • 2061
                    http://morten.myphotos.cc/probefahrt/gt2871
                    • maRS2
                      • Oct 2003
                      • 366
                      this one is GT2871 not GT28RS
                      • kalsket
                        • Sep 2004
                        • 78
                        It should be getting propper remap and full boost within 2 weeks.
                        • maRS2
                          • Oct 2003
                          • 366
                          thanks kalsket.
                          Waiting to get some news.
                          • Tommy200rs
                            • 285
                            The update with gt28rs:
                            - installed to heavy C4 Avant S4 with AAN engine
                            - AAN stock cams
                            - AAN stock IC (small and engine does not tolerate ign advance like rs2)
                            - RS2 injectors / 3bar map
                            - nice allround driving caracteristics 1800 - 3000 rpm
                            - spools quickly; turbo surges between ~2900 - 3800 rpm
                            - 4000 to 7000 rpm OK
                            • diesel des
                              • 3896
                              Can you get a biggler AR turbine housing to slightly reduce boost from 2.9K to 3.8K and so stop surge? I am sure that the map could be modified at these rpm to reduce the boost slightly in that range also. What boost is it running through surge point? What boost are you running at high rpm? Approx BHP/torque? How "laggy" is it compared to k24?
