A maf cut out uummmm so you changed to this hose because the old/oem hose was leaking or restrictive............if leaking its the same as the wastegate opening to soon.
"my setup uses a 1 bar Spring" which actually cracks open at around half a bar......so my question to you would be are you using a boost controller in your setup....and the second would be how much preload on your actuator spring have you got.
I would say quite a bit if the reported high boost levels you see , under the conditions your describeing.
I did have a go but the lock out thing completely baffled me.
