Serious compression problem!
  • Bowlerwell
    • 1052
    If you could give me advice, i'd really appreciate it.
    After having my cylinder head off, and repairing the thread on cyl 3, I now have no compression on Cyl 4.
    The problem is not with the tapits.
    What is the most likely cause?
    This might cause my car to go to the grave...
    Thanks,
    JohnB
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
    have you check the valves arent open
    • Bowlerwell
      • 1052
      The car is not with me, it's with the Audi main dealer.
      They've checked the tapits, and to investigate any more they'll need to remove the head (=very expensive)
      John Bowlerwell
      Electronic Engineer
      Present:
      Previous:
        This should be there problem since the compression & engine was fine before the head was removed, is that correct?
        • twoqu
          • Sep 2003
          • 3103
          Bit confused!
          Has the head been off or not?
          Few possibilities. The valves are open or bent. You have a piston/bore/headgasket problem. A leakdown test not a compression test would be more diagnostic. Perhaps if you ask nicely, as its only one cylinder, they might oblige.
          • s2dude
            • Nov 2005
            • 1631
            best bet...get it out of the main stealer and to your local specialist.......
            Muuuuuch cheaper!
            • Fat Audi 80
              • 10547
              Yes,
              "Step away from the main dealer and put the phone down"
              Take it to an independent. The dealer will screw you.
              The Perfectionist
              • s2dude
                • Nov 2005
                • 1631
                You could take it to the
                VW Centre in Kingwells - 01224 742520
                http://www.pistonheads.com/gassing/t...9787&f=118&h=0
                Bearing in mind I know nothing about them except soem QOC members use them!!! and its the only place i could find this far ooop north!!!
                • Bowlerwell
                  • 1052
                  Ok...
                  Yes the head has been off. But I don't think they did a compression check before they took it off... So i'm not sure if it's their problem or not.
                  My problem is that in order to find out, I have to commit to another 10 hours' labour, which I really can't afford.
                  So if anyone is interested in buying an S2 in great condition, but with 1 cylinder not compressing, give me a PM.
                  Thanks S2dude, but the car's stuck down in Cambridge. And anyway, the whole reason this happened is because the last specialist to service the car apparently didn't tighten the spark plugs properly.
                  John Bowlerwell
                  Electronic Engineer
                  Present:
                  Previous:
                  • Ross
                    • Aug 2005
                    • 3399
                    Sorry to see anyone in this situation... perhaps it's worth getting the car towed somewhere a litte more reasonable on costs, or if you can work on it yourself, all the way back up North?
                    • Fat Audi 80
                      • 10547
                      Closest specialist that I know to you would be www.theautopool.co.uk whom are well respected in Audi circles and have done a lot of servicing on my car and even the clutch...
                      If I were you, I would tell Audi to stick it, pay them what you think they deserve and have the car on a low loader elsewhere....
                      Good luck, I feel your pain.
                      Cheers,
                      Steve.
                      The Perfectionist
                        We need the equivalent of the A-team on the S2 Forum - complete with a big black van, chock full of tools, skilled hands and towing apparatus who can rescue cars like this from the evil untrained hands of the dealership...
                        Paul
                        • dm80
                          • Apr 2005
                          • 812
                          Bad luck John. Hope you get it sorted..
                          • Fat Audi 80
                            • 10547
                            [BA] I ain't getting on no plane FOOL! [/BA]
                            Great idea!
                            Can I do the cleaning up afterwards?
                            The Perfectionist
                            • SteveH
                              • 4460
                              Great idea!
                              In 1972, a crack commando unit was sent to prison by a military court for a crime they didn't commit. These men promptly escaped a maximum security stockade to the UK underground. Today, still wanted by the government, they survive as soldiers of fortune. If you have a problem, if no one else can help, and if you can find them, maybe you can hire...the S2 Team.
                              91 Modded 3B
                              14 A6 Avant Black Edition
