I am going for a Header in the feature. I was thinking about it as a temporary solution but it is for sure very interesting to see how things are going to be.
It will be nice if you asked him.
BTW what EM does Doug uses now and what turbo? When he upgraded his only change was the EM or the turbo at once?
Bilman , what turbo do you plan to run on the rs2 ex ?
What K26 hotside will you be going for ? whats the bracket for
Thats the Point i am going to try a Holset Hotside (at least for a Test). Thats why i am wondering if someone used another Housing in the RS2 EM appart from the K26 (with a Flange adapter).
I think Palle used a K26 (machined to fit the Holset Turbine Impeller). Search for Holset and Stroker Turbo thread.
