RS2 EM and Turbo-mounting
  • Billman
    • 4129
    #31
    I am going for a Header in the feature. I was thinking about it as a temporary solution but it is for sure very interesting to see how things are going to be.
    It will be nice if you asked him.
    BTW what EM does Doug uses now and what turbo? When he upgraded his only change was the EM or the turbo at once?
    Go Holset or Go RS4
    • Jon441cc
      • Dec 2005
      • 2061
      Bilman , what turbo do you plan to run on the rs2 ex ?
      Dougs set-up which he sold to Derek (daxyz)
      • Billman
        • 4129
        #33
        There is the Tricky part. I am going for a Holset
        I am gonna need for sure a Bracket or something like this. Was here in the Forum a Thread about this subject?
        I see Doug does not run the K26 8 in a Better manifold than the RS2.
        Go Holset or Go RS4
        • Jon441cc
          • Dec 2005
          • 2061
          What K26 hotside will you be going for ? whats the bracket for
          • Billman
            • 4129
            #35
            Thats the Point i am going to try a Holset Hotside (at least for a Test). Thats why i am wondering if someone used another Housing in the RS2 EM appart from the K26 (with a Flange adapter).
            I think Palle used a K26 (machined to fit the Holset Turbine Impeller). Search for Holset and Stroker Turbo thread.
            Go Holset or Go RS4
            • Jon441cc
              • Dec 2005
              • 2061
              Heres mine k26 #6 with a 65mm p -trim turbine
              • Billman
                • 4129
                #37
                Can you maybe sent pictures of your Turbo machining, assembling ect proccess?
                For what EM are you going? RS2 maybe?
                Go Holset or Go RS4
                • Jon441cc
                  • Dec 2005
                  • 2061
                  I'd love to Bilman but i haven'ta clue ... I bought the T04e high output from javad two years ago.
                  I'm using a tubular now but i did use the turbo with a s2 manifold
