Well,
I have change MAF, ISV, TPS, PLUGS, Lambda, Dizzy, Fuel Filter, Fuel pump.
Problems is that sometimes the car will suddenly start to stall. This happens if you press the clutch, then it will drop to 500 rpm and then go back up.
Or if you just slightly press the gas pedal, it will drop to 500 rpm and then go up.
This does seem to be worse when I have been driving in traffic for some while.
Also taking the maf plug off, will help sometime.
But the strange thing is that wenn it suddenly start to go bad, it also seems to be running rich. Now is there anything in the ECU, that can cause the car to over fuel?
I think this is an electrical problem, but i am not sure.
Well any suggestions are welcome, also it is not the ISV. It only drops down to 500 rpm and then go back up and then stays rock solid on 800 rpm.
/Jonas R.
/Jonas R.
