Sluggish when cold
  • Sluggish when cold
    The behaviour of the old girl has been a bit naughty when cold, with lumpy running under power and the need to give the throttle a good prod to get going. It's all gravy when warm. Starting behaviour seems a bit off too, where once it fired in to life it's more of a cough now but still catches first time.
    Culpritsulprits are lambda warm-up and MAF. Will check the codes and do some digging but in the meantime, any ideas?
    K24 Racing - K24R Products
    Sticky icv?
      I'll give it a clean. Idles perfectly.
        IAT sensor ?
          No codes so cleaned the MAF connector again and checked it all over. Seems better.
          Need to fit my new pins! And buy a new MAF I think
            Pesky maf connector again!
              G28 on the back of the head....always caused cold start issues on mine when on the way out
              1992 3b S2 Coupe
                Bad lambda heating. Had similar troubles when cold. When it warmed up, went as usual. Replaced the probe and the issue was gone.
                  Yes, lambda heating is an option. I wonder about coil pack too but tbh I think that would be worse when running. Will grab a new lambda (again) and try that. Gen Bosch lambda has done maybe 5k...
