S6 wont start
  • S6 wont start
    I haven't driven my car in 2 years. I tried Starting it but it just turns over, almost sounds like there's no spark.
    I checked and there is spark, timing is spot on and I've got half a tank of fuel.
    any ideas of what the problem might be?
    [SIGPIC]1997 Ur-S6 SMS Revo S
    Maybe the fuel pump has failed?
      Originally posted by audi660 View Post
      Any ideas of what the problem might be?
      First thing: Make sure the battery is fully charged. If the cranking speed is < 13 RPM, ECU will not trigger the J17 Fuel Pump relay.
      While you are waiting for the battery to charge up, try reading Item 4 in the Monthly Reminder list that I just bumped 7 days ago:
      https://www.s2forum.com/forum/welcom...-forum-members
        http://forums.quattroworld.com/s4s6/msgs/210191.phtml
          Which is Item 4 in the monthly reminder list, i.e. Potential solutions to why your AAN-powered UrS isn't starting
            I checked the fuses above the ecu and they are a fine.
            I pulled the fuel rail out and cranked the engine but no fuel is coming out
              You are never going to get your engine started if that is the extent of your diagnostics. Please please read the link that has been suggested and start with charging your battery to full capacity, i.e. 12.7 volts. No > 13 RPM = no activated fuel pump relay, etc.
                I charged the battery and the fuel relay works when I crank the engine
                  Not sure how you established that but okay. Now you need to consider the cam sensor being at fault. Any codes?
                  HOW TO PULL CODES ON A C4 UrS:
                  http://forums.quattroworld.com/s4s6/msgs/323125.phtml
                    But is the fuel pump actually pumping?
                    I think you said you had no pressure at the rail?
                    If the fuel pump relay is closing but there's no pressure at the rail then it points to a bad pump.
                      I'll disconnect the fuel feed at the fuel rail and see if I get fuel. If I do, then the injectors are blocked. If no fuel, then it's gotta be the fuel pump
                        Fuel = Item 4.3 in my list of reasons why "your" AAN won't start: http://forums.quattroworld.com/s4s6/msgs/210191.phtml
                        There are better ways to test the fuel pump:
                        http://forums.quattroworld.com/s4s6/msgs/260108.phtml
                          I have fuel pressure at the rail but the fuel I not going into the fuel rail. I tried another fuel rail and 3 different fuel pressure regulators but the fuel isn't getting to the Injectors.
                            Have you actually cranked the engine and pumped fuel out of the feed line into a container?
                            If you have then check the 12v suppy to the injectors with a multimeter.
                            • #15
                              Originally posted by newsh View Post
                              Have you actually cranked the engine and pumped fuel out of the feed line into a container?.
                              Agree but even simpler to jumper the fuel pump power and test whether it is working, independent of the FP relay, as per my Fuel Pump Testing DIY:
