7a block stroker
  • 7a block stroker
    I’m thinking of building stroker short block from a spare 7a block I have in garage. I’m using 95.5mm crank also it’s going to be turbo not n/a power would like people who have done this what rod to pistons you went for
    FCP engineering has a set they can order for you.
    I plan to do the same but with smaller pistons
      I’ve asked fcp already but not had a answer on rod length to use
        I don't think FCP make a piston for this combination of parts, I think you're going to need a 144mm rod with a custom piston.
          I was told that is need 144mm with custom pistons they have the spec for. Difference is the piston size which they can order as well
            Hi Andy fcp said they use 144mm rod with a custom je piston they get
              Yes same here
                Jonus has a kit for the 220mm short block.
                  I have requested a set of pistons that has the 4032 T6 alloy that expands less. I don't like oil consumption. Hopefully they can make one
                    Yes he does I’m hopeing to get to look at a set very soon thanks Alex
                      Are they je pistons?
                        Yes JE can make that alloy too
                        Sent from my SM-P550 using Tapatalk
                          I have unicorn crank for that kind of setup, 92.8mm
                          Then u can use 144mm rod and cheap supra or tfsi piston, also positive ise u have less stress on engine, better piston speed and rod/stroke ratio.
                          Crank is original, have whole abt c5 coupe engine
                            What's the best comp ratio to go for , for such an engine. Boost no.more than 2bar
                            • #15
                              The pistons I’ve been told to use are 8.5 comp
