Timing belt change
  • Timing belt change
    I've had my 93 ABY Avant for over 3 years now. I had been told the belt and pump had been changed when i bought the car but after checking i could not find proof of it being done in the documents. As peace of mind i want to change the belt, water pump and tensioner. Am i best sticking with Genuine Audi parts and if so where is the best place to get them?
    I would recommend parts from INA, SKF and Contitech. The same products as Audi sells but for half the price.
    I also would change the toothed belt pulley on the crankshaft, they break very often!
    Be aware that you need a special tool (VAG 2084) to get the big screw in the crankshaft opened.
    '95 Audi S2 Avant
    '92 Audi Coupe T89 quattro 2.3E
      2084 doesn't work on the ABY. I fitted a Gates belt and Valeo water pump to mine
      Mike
      http://www.s2-audi.co.uk
        Thanks guys! I was planning on making a locking tool up if I can't find one. I was reading that the bottom pulleys sometimes fracture. I think I will get that changed while I'm doing this. Bloody alternator gave up the ghost heading home from work today so will be another job to Do!
        Will I need a new crank bolt or can I reuse the one I Have?
          You can reuse the old bolt. Where are you based - I may be able to lend you the locking tool
          Mike
            Definitely replace the crank pulley, this is the one just come out of my coupe, I got lucky..
              That would be handy. I'm in Dumfries SW Scotland. I would be happy to come a run on my bike and collect it.
                Get a CrMo sprocket off Terrybullwon on here.
                Gates cambelt (they are the OEM) - Gates p/n - 5269XS
                INA idler bearing/pulley (they are the OEM) - INA p/n - 531 0731 10
                SKF water pump - p/n VKPC 81612
                Potentially worth changing the hall sensor while you're in there, depending on its age etc - Bosch 0 232 101 020
                HTH
                  Just borrowed a tool made for AAN and found out it wont fit for V-belt damper, botched together a new one. Inner diameter of the damper is ~67mm.
                  1989 Audi 80 Quattro
                    I need one of those CrMo pulleys. PM sent to Terrybullone.
                      My pulley arrived today and is master crafted perfection!
                      Well done Terrybullone.
                        They are lovely aren't they
                          Yes you are right! The pipe is too short for ABY engines, i forgot this.
                          I had to modify my 2084.
                          '95 Audi S2 Avant
                            Got my pulley today. Looks like a good bit of kit. I went with a Gates belt and an SKF water pump.
                            • #15
                              Excellent choice.
