rs2 cold start trouble
  • rs2 cold start trouble
    hi ,
    first, i apologize for my poor english ;-)
    here is my problem :
    since a few weeks , at cold start , my engine tumble ant stops , and when i WOT it stays at low revs , and some exhaust and intake explosions occur .....
    at iddle it seems to run on 4 cylinders ..
    and after a few time (5 minutes) it sudenly run fine.
    the are 5 new plugs on it .
    thanks for your help
    Has it been sat for a long time? Any signs of damp in connectors and sensors? Have you pulled fault codes?
      i' haven't a diag system .
      The car is runing every week or starting at least every month on cold season
        Check the wiring plug to the white sensor on the back of the cylinder head. The ECU uses this sensor for coolant temp. Maybe it gives a false reading during warm up.
          I had similar symptoms with my S2 ABY and it turned out to be this.
          This gallery has 1 photos.
          1996 S2 ABY Coupe silver
          2003 S3 8L dolphin grey
          2014 RS4 B8 prism silver
            the wiring seems to be ok , so i disconnect the sensor , and it runs fine....
            So , is this critical to run without this, sensor , while i will found a new one ?
              thanks for the help guys !!!
                I offer you the following:
                Missing and Hesitation diagnostics:
                http://forums.quattroworld.com/s4s6/msgs/22611.phtml
                Power Output Stage Diagnostics:
                http://forums.quattroworld.com/s4s6/msgs/153152.phtml
                G62 Coolant Temp Sender used by the ECU to control fuelling:
                http://forums.quattroworld.com/s4s6/msgs/20985.phtml
                  I dont want to make new topic. My car makes also same but has 3B engine. What sensor it can be. If engine is gold then rpm goes between 400-1000rpm. About a minute it will be steady.
                  What would be normal rpm with cold engine? Mines always been 800rpm. Cold or warm.
                  Also RPM-s will go crasy if i will stop before stop sine and then it will also do like it was gold engine. But after 20 minutes of ride, everything goes ok.
                    Check out your idle stabilizer valve to make sure it’s moving freely. You can run output tests with a simple blink code lead yourself. If not check the temp sensors as listed above
                      Does those things you mentioned also make engine stutter? I today started car and it looks like only 3-4 cylinders work. revs jumped 300-1000rpm. After 10 minutes of ride and car was perfect again.
                        finaly that wasn't the temp sensor ... i disconnect the blue connector on the bipass on the oil gaz recirculating circuit ... this is located near the ECU temp sensor ...
                          Anyone?
                            this symptoms are nearly the same as mine, disconnect the blue connector on the oil vapor recyrculating circuit, under the throtle bodie .
                            just for test , if its this your engine may run fine just when you disconnect this
                            • #15
                              I have 3B engine. Its little different.
