It is a 60 tooth trigger, just with 2 “missing”. The teeth are spaced at 6 degree increments.
How can it be at a different angle from one phase to the next, it’s fixed to the crank
Do they mean the cycles overlap the engine phasing? Sounds like they have not thought their trigger decoder out to suit 5 cyl....
EDIT: Just to clarify, have you had the car running on this ECU using the stock 3 sensor trigger setup?
