Evening all, I need to replace my main radiator and can anyone confirm for sure if Hella 8MK 376 711 281 is the correct replacement for an S2 ABY (Avant)? - I do intend to keep using the aux rad by the way.
I found this part number by searching the forum, but on various car part websites it states this isn't compatible and only lists it for the 2.3 quattro . I have already got an unopened 8MK 376 711 284 which I now believe to be wrong and guess I need to return it
Does anyone have either of these fitted to their car? Or can you suggest another alternative that is in stock.. anywhere?!
