2.5L Engine
  • AnotherProjectCar
    • Oct 2018
    • 3
    2.5L Engine
    I am interested in upgrading a 3B to 2.5L. does anyone know which block to use for this task.
  • AndyP
    • 6049
    Are you really in the USA? I have one for sale if you're interested?
    • PRY4SNO
      • 767
      Are you going for a tall deck stroker with a diesel crank? If so, I'd stick with an AEL or AAT.
      If you're going for over bored pistons, basically any block you can find domestically should do the part.
      2013 Touareg TDI /// #farmenwagen
      • AnotherProjectCar
        • Oct 2018
        • 3
        What is the AEL or AAT?
        • taren86
          • Nov 2013
          • 40
          • Home: Estonia Current: United Kingdom
          Hi. Im done it. Indigence what system are you want to leave. Im using 60-2 on the flywheel and vems combination . what i need to upgrade on the block just blanket the hole for the engine breeder.
          If original system. need make the space for the sensors.
          • Henkjan
            • 1705
            engine codes
            • De80q
              • Nov 2016
              • 56
              I'm about to pull the trigger on a eruovan bottom end. But then again, I'm one of the few weirdos left trying to build 10vt power...
