I am interested in upgrading a 3B to 2.5L. does anyone know which block to use for this task.
2.5L Engine
Are you going for a tall deck stroker with a diesel crank? If so, I'd stick with an AEL or AAT.
If you're going for over bored pistons, basically any block you can find domestically should do the part.Find me on Instagram @pry4sno
2010 Golf Sportwagen TDI /// #farmenwagen
2002 Dodge Ram 2500 24v Cummins 4x4
Hi. Im done it. Indigence what system are you want to leave. Im using 60-2 on the flywheel and vems combination . what i need to upgrade on the block just blanket the hole for the engine breeder.
If original system. need make the space for the sensors.
