6) OK then as per 20v.org the connectors would be in the driver's foot-well. The ends of them look like this:
They are roughly above where your left foot goes, originally likely attached to the bottom of the dash, right where the carpet disappears up behind the dash, mine where just hanging loose back there.
7) IIRC, in that manual there is an illustration of the instrument panel and a list of what the little lights idiot lights in the cluster all mean, correct? Perhaps it lists the CEL, yes? What all lights up during your start sequence currently?
8) If you don't have a functional CEL you will have to either make one light in the cluster work as one or use a hand-held 12v test light (home-made like at 20v.org or store-bought). Some bed-time reading:
9) What about a jumper cable, do you have one of these?
10) Further reading, in your case (a 7A engine) ignore the 2 x 3 connectors:
Want even more reading, photos above came from the SJM website, lots of applicable stuff to read there also:
sjmautotechnik.com
sjmautotechnik.com
