Right! I'm going to need to be able to adjust the fuel pressure on my B3 S2 Re-shell Saloon Project, so I'm after recommendations for the best adjustable FPR one can purchase, what are the best brands and models? The choice is quite baffling and I've never needed to use one before so any advice regarding what to buy would be much appreciated.
Also I want to be able to fit a sender to the fuel rail for an electrical gauge in the car, I could hook it up to one of the inputs on my Zeitronix or have a dedicated gauge I don't mind doing either, what is the best way of going about this?
Space is not an issue as I'm fitting a manual steering rack and completely doing away with the hydraulics to free up space and make things as simple as I can in the engine bay, no Evap system or ABS either, everything I can get rid of is going as I'm trying to keep the weight down to around 1150 kg's.
Any advice welcome.
.Also I want to be able to fit a sender to the fuel rail for an electrical gauge in the car, I could hook it up to one of the inputs on my Zeitronix or have a dedicated gauge I don't mind doing either, what is the best way of going about this?
Any advice welcome.
