water / methanol Questions
  • water / methanol Questions
    hi all I’m looking at putting a water/methanol system on the s2. Just need some info like what systems to use, where to instal the injector and what size jet I need. Thanks in advance
    When I did mine I fitted the jet in the end tank of the intercooler. Mine is very mild so I think I have a 0.8mm injector
      Thanks for the info. That’s where i was think of putting it has i run a large intercooler. Just unsure what make to use and the size of the jet that’s all.
        I believe you should get a assortment of jet sizes and some advice on what jets you should use. Regards Lynn
          Thank you. I really need to ring a manufacturer up but need to know what systems and what manufacturers are best thanks
            I have a aquamist HFS3 for sale with everything needed including different nozzles etc.
            PM if that would be interesting and then we can sort out a price.
            Sleeper S2 Avant +450
            A6 Avant 2.7t Stage 3
            Audi S2 Coupe RS2'ed
              Aquamist is the make that we have fitted in the past to the Turbo bike's at Big cc racing. Very good kits although we just charge cool nowadays.
