Hi guys.
I will be replacing exhaust system on my S2 and on removal of down pipe i have found that some of nuts on exhaust manifold are loose and four of them are just missing
I cant believe that it wasn't blowing past the gasket .Anyway im after advise how to prevent it from happening again?
it is Wagner manifold and I have used original nuts and the washers and I'm thinking of not using them washers anymore .Also now when the turbo (KKK7200)is removed would it be good time to do some mode to it??I was thinking about billet wheel,360 bearings etc ?What's your thoughts guys ?
thanks
I cant believe that it wasn't blowing past the gasket .Anyway im after advise how to prevent it from happening again?it is Wagner manifold and I have used original nuts and the washers and I'm thinking of not using them washers anymore .Also now when the turbo (KKK7200)is removed would it be good time to do some mode to it??I was thinking about billet wheel,360 bearings etc ?What's your thoughts guys ?
thanks
