urgant help needed with ABY not starter
  • flat out 90
    • May 2017
    • 233
    It doesn’t have a aftermarket alarm on it.
    • Lago Blue
      • Jul 2009
      • 843
      Re central locking, Is Dave's "role of the J219 relay" post possibly applicable here:
      • flat out 90
        • May 2017
        • 233
        https://www.s2forum.com/forum/techni...cuit#post77820
        Ok so I tried the jumper one and iv tried a few other relays with no luck
        • flat out 90
          • May 2017
          • 233
          So iv read some where about wires getting fought in the steering column and making all sorts of problems. Iv chequed that but does anyone have any other places that may be a problem
          • Lago Blue
            • Jul 2009
            • 843
            Was the current ignition switch a new genuine VAG part, after-market, or used, and could it be proven elsewhere?
            • flat out 90
              • May 2017
              • 233
              It’s a after market one and I’ll go and try it on the other car.
              • Dynasty
                • Jan 2015
                • 79
                • Country: Norway
                #67
                Is the fuel pump running when you try to start it with the key (do you have fuel pressure)?
                • flat out 90
                  • May 2017
                  • 233
                  Yes have fuel and fuel pressure
                  • predding
                    • Aug 2009
                    • 132
                    #69
                    Hello FO90 - did you find the cause of the non-start as I am having very similar problems ie engine whizzes over on new battery, strong sparks at plugs and plugs wet with fuel but nothing. Thanks for any feedback
