There is a relay that makes the X rail live, but I don't think the ECU is fed off the X rail as that goes dead on cranking. I had issues with it on an old 90 I ended up just shorting it out
I will say though things are getting hot like the ecu Is getting hot when the ignition is turned on. Not red hot but hotter than what I think it should be
