Even with the ecu unplugged I’m still getting the injectors open.
urgant help needed with ABY not starter
Ok it’s just nothing is making sense at all. It’s like the injectors are open all the time that’s what really doesn’t make senseComment
Possible but that’s a new has before I wasn’t getting any fuel or spark but still not getting a sparkComment
May be I’m doing it wrong but with the ecu unplugged there is still 12vs on both sides of the injector plugComment
I will say though things are getting hot like the ecu Is getting hot when the ignition is turned on. Not red hot but hotter than what I think it should beComment
Yes all wires checked and hall sender replaced. From a known working one. When I do the led test it shows it’s working fine.Comment
That’s normal. The injector won’t open till the ECU grounds one side.Originally posted by flat out 90May be I’m doing it wrong but with the ecu unplugged there is still 12vs on both sides of the injector plugComment
