Originally posted by ryster
View Post
ABY Ecu Has blown!!!??
Originally posted by ryster View PostI seem to have the same problem engine was started from a boost starter started up fine (slight mis fire ) Move it car stopped tryed to boost start it again . Noticed a mouse had chewed a coil pack wire . Sorted wire but it wouldn't start ! Notice one if tge main fuses had blown The ecu memory fuse . Fuse keeps blowing .
so i removed ecu Changed fuse turned ignition one fuse was ok reinstated ecu turned ignition on blow fuse again .
when the best place to get ecu checked ?
s2 central put a chip in it years ago . I have had the off the ecu looks and smells ok .but i need it tested can anyone help please ?
