Boost cut after fitting TFSI coils?
    Yes it sounds like a MAF connector problem to me.
    • CREASE
      • Oct 2008
      • 120
      • Home: Jersey Current: United Kingdom
      Had same symptoms with same apparent reset from turning off-back on, replaced knock sensors-found shielding to be fubar.
      Problem solved! Worth checking bud
      • le mans
        • Nov 2013
        • 165
        • Country: New Zealand
        Anything in the fault memory to give you a clue? I would have thought a boost cut would register a code.
        • Jolfa
          • Dec 2009
          • 468
          • Home: United Kingdom Current: New Zealand
          Would unplugging the MAF entirely get around that possibility? Because that changed nothing other than idling rough
          • Jolfa
            • Dec 2009
            • 468
            #20
            Just for the benefit of future seekers of answers for this ballache, it took a full 5 years to get to the bottom of it but I finally cracked it!
            It was cheap sh*tty Chinese injectors had sh*t the bed, moral of the story buy cheap buy twice, you can't get real Bosch Green Giants for under $100 a set
