ARP head and main bolts torque spec?
  • ADP
    • Mar 2011
    • 200
    • Home: Bulgaria
    Hello mates!Im runing into little doubt regarding the proper torque spec of mains and head studs from ARP!
    Someone can give me advices please?
  • LHD_Kid
    • May 2006
    • 3695
    The search function is your friend.... ​​​​​​
    Post #102
    • ADP
      • Mar 2011
      • 200
      • Home: Bulgaria
      Many thanks LHD Kid
      • Antsa
        • Nov 2016
        • 611
        Head studs to block : fingertight
        Head nuts : 90nm, don't use the small washers provided by arp. Get bigger ones. Re-torque after first run. These instructions are from finnish Audi forum from member Repo.
        Main studs: if the thread pitch is the same as oem use oem torque. Otherwise use the torque provided by main studs supplier. If the thread pitch is finer than oem and you torque them to oem spec, the main caps won't be round anymore.
        • ADP
          • Mar 2011
          • 200
          • Home: Bulgaria
          Yes im worry obout roundnes ot the main caps,now all of them are 0.03mm when its tight with original bolts ?did i nee to make rehone of the main tunel?
          • ADP
            • Mar 2011
            • 200
            • Home: Bulgaria
            Many thanks, Antsa!
